주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
iPhone 5s Battery Replacement
Tom -
iPhone 5s
스토리 이미지
  • 이미지 #1
  • 이미지 #2
  • 이미지 #3
How to replace the battery in your iPhone 5s
30 분 - 1 시간
Moderate
내 문제
The battery went dead very fast.
나의 수리
Removing the battery was incredibly difficult. I installed the new battery but had to put phone back together 5 times before I could get the screen to work. I had no problem with parts I got from iFixit.
내 조언
When removing the battery try not to fold the battery at all. If the battery folds it can cause a short and explode in your phone this is what happens when trying to remove it. Try to make sure your battery is dead all the way before you change it.
iPhone 5s Battery 이미지
iPhone 5s Battery
$29.99
« 모든 스토리로 돌아가기
댓글 3개
The 5S battery is a real pain to remove. at th ebottom of the battery is a black plastic tab that you can pull on to remove the adhesive holding the battery in place, but 9/10 time it rips off without removing the adhesive.
The only way I have found to get the battery out without it bending too much, is to use a heat gun and heat up (not too much!!) the back of the phone where the battery is sitting. Then use a thin flat spudger or similar to get under the battery. Normally the battery casing rips as the glue holding it in place is overkill on Apple's part.
Harvey - 답글 공유
When you first remove the dock connector, you can really easy pull the black plastic tape without breaking it.
Marvin - 답글 공유
Tom,
Im sorry you had a difficult time replacing the battery on your iPhone 5s. For first timers it can be a bit tricky. For future repairs on your mobile devices by all means contact me for help or advice just click on my name gillrios to get me email and contact info for my business G3 Mobile.
gillrios - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 18
전체 시간: 645
