주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Coffeeshop Phone Surgery
Kenna Warsinske -
Samsung Galaxy S4
스토리 이미지
Samsung Galaxy S4 USB Board Replacement
30 분
Moderate
내 문제
The charging port was going bad and throwing errors. You can see from the photo that I'd already replaced the battery trying to troubleshoot my problem.
나의 수리
I decided to do the repair while hanging out at a coffee shop since I wasn't applying glue or other weird toxic stuff. The tables wipe down very clean, so I didn't have any worries about getting gross stuff in my phone. Much cleaner than my own desk.
The repair was fast and simple once I got the case fully open. Weirdly, the middle bit of the case (left) was the hardest part to get off. I used a screw grabber (the yellow thing), needle nose tweezers, a spudger, and a mini screwdriver. Your part arrived in perfect condition and fit perfectly with no fussing. The two wires connected to the charging assembly took a little extra pressure to pop back into place and they weren't mentioned in your tutorial, but other than that, your tutorial was helpful and accurate.
내 조언
Needle nose tweezers were helpful for holding certain screws when I was putting it all back together. Also a spudger is a MUST these days. I used to be able to get away with a fingernail and a credit card, but not anymore. Very lucky I had one hanging around.
Galaxy S4 (Verizon) Charging Assembly 이미지
$12.99
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 303
