주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Petzl Headlight button repair
Gavriil Kamaris -
스토리 이미지
  • 이미지 #1
  • 이미지 #2
내 문제
The rubber covering the On?Off button was destroyed after years. The PCB was revealed making the circuit vulnerable to dust and moisture and the button difficult to locate.
나의 수리
I cut a transparency slide oval part to avoid the glue going all over and create a spring like behavior and also designed and 3D printed a small pin to push the button. Then i covered the assembly with mouldable glue (like sugru) to reform the rubber cover. All went well and the button is working fine
내 조언
Please contact me if you need any designs for the 3d print pin.
« 모든 스토리로 돌아가기
댓글 1개
Well done! 👌Will come back to this when my Petzl button fails
Susanne - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 251
