주요 콘텐츠로 건너뛰기
I was only six when my parents introduced me to this machine. Now, 12 years later, I'm taking a look inside before saying my last farewell as it heads off for disposal.
필요한 것
도구
해당 분해도는 수리 안내서가 아닙니다. 2004 Advent 7081 수리는 자사의 서비스 설명서를 사용하세요.
    • Firstly, out comes the battery. just a lock and a switch much like modern laptops which still have a replaceable batteries.
    • The broken left mouse button on my machine also gets removed since the sellotape holding it in would probably annoy me later.
    • Two phillips 0 screws hold down the panel hiding the hard drive from view.
    • It is a Seagate 40GB model which appears user upgradeable... It's even mounted to a quick-release drive caddy.
    • Attempting to free the drive from the cage we find the first warranty sticker. All this means is I'm headed in the right direction!
    • Two annoying screws later and the drive slips free of its hot-swap cage.
    • Only a single screw this time... and we're in.
    • W e are greeted with a 256MB DDR SODIMM. This could have been upgraded to 1GB back in the day.
    • One of the screws here is screwed into a cracked hole in the panel. I guess living with two young children, as my brother and I were at the time, will have taken its toll.
    • The intake fan is remarkably clean given the amount of use... I can remember this thing howling under a heavy load.
    • Many screws hold the bottom panel tohether, inclusing one deeply set in the plastic, requiring a long-shaft screwdriver.
    • One of the screws holding the optical drive in place needed to be drilled out since it would not come loose.
    • Unfortunately something wouldn't budge and I was not able to pull the cover off any further with my (lack of) expertise. Don't worry there's still one more thing of interest.
    • After removing the heatsink we get to see the CPU - an intel celeron M350 clocked at 1.34 GHz.
    • It has an unusual screw-actuated lock, which can be released to allow the CPU to be removed.
작성자
2다른 기여자 명과 함께
Henry Taylor
회원 가입일: 03/19/17
133 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 341
