주요 콘텐츠로 건너뛰기
I teardown a common DTV converter to see whats in it and debunk the "camera" nonsense. This little box has 16MB of RAM and an unknown speed CPU. Well, lets find out!
필요한 것
도구
해당 분해도는 수리 안내서가 아닙니다. Access HD Digital Converter 수리는 자사의 서비스 설명서를 사용하세요.
  1. Access HD Digital Converter Teardown, Access HD Digital Converter Teardown: 1 단계, 이미지 2개 중 1개 Access HD Digital Converter Teardown, Access HD Digital Converter Teardown: 1 단계, 이미지 2개 중 2개
    • Ah, the tiny little box. Reminds me in size of the new Apple TV. Yay for cheapo silver paint. What do you expect for 20 dollars?
    • To open it, you must remove 3 screws. 1 on the back, and 2 on the bottom behind rubber stickies.
    • There is also 1 clip you must undo on the back, it's visible.
    • The device takes OTA digital signals and converts it into analogue 480p. Ironic that it's called Access "HD". Composite or coaxial are your choices here.
  2. Access HD Digital Converter Teardown: 2 단계, 이미지 2개 중 1개 Access HD Digital Converter Teardown: 2 단계, 이미지 2개 중 2개
    • Once the cover comes off, you must disconnect the front button cable.
    • The front button board does not have much on it. Buttons, 2 color LED and an IR receiver.
  3. Access HD Digital Converter Teardown: 3 단계, 이미지 2개 중 1개 Access HD Digital Converter Teardown: 3 단계, 이미지 2개 중 2개
    • The Motherboard only takes up 2/3 of the case. The rest is empty plastic!
    • Unknown CPU with a clock of 100mhz and 16mb of on board RAM. Contains a composite video encoder and some kind of simple video controller capable of 480p resolution.
    • 4mb Flash DRAM which contains an unknown simple menu driven OS. No advanced features whatsoever.
    • Composite video output, Power in jack
    • RF Transceivers
    • Not much to this little device. It works well at picking up free over the air television. It tends to run hot, so the CPU must not be well designed for such a simple task as decoding MPEG4 streams.
작성자
3다른 기여자 명과 함께
Zenitar
회원 가입일: 02/07/10
191 평판
안내서 2개를 작성함
2가이드 댓글
Taking the top off a product is not a teardown. :(
Ryan Guerra - 답글
I have 2 decoders that have failed,,this is one of them. Seems to have power but doesn't decode. Need to know how to test parts and replace.
Peter Cieply - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 6,591
