주요 콘텐츠로 건너뛰기
Ding-dong, the dongle's here! Google knows that cat videos are more entertaining when viewed on a 72-inch HD display, so they packed Chrome into a compact dongle, threw an HDMI output on it, and provided the world with the cat videos we deserve! Join us as we tear down the Chromecast to find out how Google squeezed so many cats into one small package.
Want to stay in the loop with our most recent goings-on? Follow us on any or all of our social media outlets! Fixin' for some filters? Instagram it is. More of a text person? Twitter! Enjoy compound words? Say hello to Facebook.
필요한 것
도구
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
해당 분해도는 수리 안내서가 아닙니다. Chromecast 수리는 자사의 서비스 설명서를 사용하세요.
  1. Chromecast Teardown, Chromecast Teardown: 1 단계, 이미지 3개 중 1개 Chromecast Teardown, Chromecast Teardown: 1 단계, 이미지 3개 중 2개 Chromecast Teardown, Chromecast Teardown: 1 단계, 이미지 3개 중 3개
    • Upon eagerly ripping open the Chromecast's box, we are greeted with more than just a dongle.
    • The dongle's specs and features:
    • 1080p HDMI output
    • 2.4 GHz WiFi 802.11 b/g/n
    • 1080P maximum output video resolution
    • USB-powered
    • Compatible with a variety of devices, including both iOS and Android devices
  2. Chromecast Teardown: 2 단계, 이미지 1개 중 1개
    • The Chromecast's sole port is the USB charging port. As if TVs don't have enough wires already, your favorite new dongle requires external power via USB.
    • When we hear "dongle," we don't usually think of external power. The Chromecast, however, requires external power via an available (non-service) USB port or via the USB charging cable and adapter.
    • At least Google sort of mentioned this…
  3. Chromecast Teardown: 3 단계, 이미지 1개 중 1개
    • Model Number: H2G2-42.
    • Wasn't "42" the answer to life, the universe, and everything in The Hitchhiker's Guide to the Galaxy?
    • And H2G2 is an abbreviation given to the book, as well as the name of a website dedicated to making a guide to life, the universe, and everything.
    • We see what you did there, Google. Your clever nerd humor will not be lost on us!
    • Call us speculative, but it appears Google thinks this device is the answer to life, the universe, and everything.
  4. Chromecast Teardown: 4 단계, 이미지 2개 중 1개 Chromecast Teardown: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heat Gun
    $24.99
    • To our relief (and maybe a little disappointment), it seems as if we won't need to pull out the big guns to get this little guy open.
    • A plastic opening tool exploits the seam of our dongle, and just like that, we can start pulling out components.
    • Yes, we do enjoy typing the word "dongle."
  5. Chromecast Teardown: 5 단계, 이미지 2개 중 1개 Chromecast Teardown: 5 단계, 이미지 2개 중 2개
    • The first thing out is, well, everything. Pulling the motherboard assembly out of the Chromecast leaves us with an empty shell.
    • Almost empty, that is, except for some excessive thermal leftovers and a big hunk of aluminum heat sink.
  6. Chromecast Teardown: 6 단계, 이미지 3개 중 1개 Chromecast Teardown: 6 단계, 이미지 3개 중 2개 Chromecast Teardown: 6 단계, 이미지 3개 중 3개
    • The central nervous system:
    • AzureWave AW-NH387 802.11 b/g/n WLAN, Bluetooth and FM Combo Module
    • Marvell DE3005-A1 System on Chip
    • Micron MT29F16G08MAA 16 Gb (2 GB) NAND Flash Memory
    • Micron D9PXV 512 MB DDR3L SDRAM
    • DDR3L SDRAM (1.35 V) is a low voltage version of the DDR3 SDRAM (1.5 V).
  7. Chromecast Teardown: 7 단계, 이미지 2개 중 1개 Chromecast Teardown: 7 단계, 이미지 2개 중 2개
    • With the motherboard out, only one component remains: a (relatively) ginormous heatsink. Made of solid aluminum and spanning the entire length of the device, it rests—lifeless hardware in a tiny coffin.
    • We can't say we're surprised, though, as the product information states "Chromecast may get hot to the touch; this is normal."
    • This is somewhat disconcerting, sort of like "melt in your hand, not in your mouth," or "side effects may include death."
  8. Chromecast Teardown: 8 단계, 이미지 1개 중 1개
    • We’ve decided not to assign a repairability score to the Chromecast.
    • There’s just nothing in it to repair. The Chromecast is essentially a luxury item with a limited use.
    • Best hope for this little guy: after a long, fulfilling life of streaming kitten videos, the Chromecast is recycled responsibly.
작성자
9다른 기여자 명과 함께
Jake Devincenzi
회원 가입일: 04/18/11
118,193 평판
안내서 57개를 작성함
댓글 27개
HDMI 1.4 can power the device without USB power.
msgalicki - 답글
Thanks, that's great to know..
Harry Hawk -
This is incorrect, people have tested this and it doesn't work.
Charlie Skog -
Dongle, dongle, dongle... yes, it is a fun word to type.
Any warning which includes the phrase "this is normal", clearly indicates something which any normal person would realize is not normal.
Rylan Luke - 답글
Next teardown a Galaxy Minstrel .... or was that just a British thing? They don't melt in your hand (according to the advert anyhow) www.youtube.com/watch?v=R8ggWmC_Cpg‎
Bees -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 146
전체 시간: 282,852
