주요 콘텐츠로 건너뛰기
소개
This is the Microsoft Surface Book 2, and just like every Surface device we’ve done a teardown on this year it scored horribly on our repairability scale. How bad did it do? We gave it a 1 out of 10, which to be honest is at least a little better than the Surface laptop which got a zero but still. So today I’ll be essentially walking you through how to design a device that’s terrible for repair.
필요한 것
도구
더보기...
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Microsoft Surface Book 2 수리는 자사의 서비스 설명서를 사용하세요.
    최종 의견
    • After the difficult opening procedure, the SSD can be replaced.
    • The display assembly consists of a fused glass panel and LCD, and is difficult to remove and replace.
    • The processor and RAM are soldered to the motherboard.
    • Strong adhesive holds many components in place, including the display, base cover, and both batteries.
    • Many components are on the backs of their respective boards, requiring motherboard removal to replace simple components.
    수리 용이성 점수
    수리 용이성 10점 중 1점
    (10은 가장 쉬운 수리를 뚯함)
댓글 34개
Any chance we will see a 15 inch teardown?
Samuel Young - 답글
I agree with Mr. Young. The 15 inch model houses the new Core i7 8650U, a quad-core processor, as well as a discrete graphics card, the GTX 1060. Any chance that you might be taking a look into that?
Ethan Z -
Will there be a written version?
Liam Powell - 답글
Can you swap the ram? (with effort)
Maxi “Maxam” W - 답글
As stated in the video, no, the ssd is removable but the, ram, cpu, gpu etc are soldered onto the board
Pierce Sonnenberg -
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 182
지난 30일: 824
전체 시간: 152,072
