주요 콘텐츠로 건너뛰기
The SteelSeries Arctis 1 Wireless Gaming Headset was released on September 3, 2019. It retailed for $99 on release. It comes with the Headset, microphone, USB-C Reciever, and Micro-USB charger.
These are my personal pair, so I will be attempting to do this in the most non-destructive way possible.
This is also my first guide ever, so I apologize for any inaccuracies in information.
Have fun!
필요한 것
도구
더보기...
해당 분해도는 수리 안내서가 아닙니다. SteelSeries Gaming Headset 수리는 자사의 서비스 설명서를 사용하세요.
  1. SteelSeries Arctis 1 Wireless Headset Teardown, Basics: 1 단계, 이미지 2개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown, Basics: 1 단계, 이미지 2개 중 2개
    • The Basics:
    • Microphone port
    • Power button and LED
    • Micro-USB port
    • AUX cord IN
    • Volume wheel
    • Microphone mute/unmute
  2. SteelSeries Arctis 1 Wireless Headset Teardown, Remove Ear Cushions: 2 단계, 이미지 3개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown, Remove Ear Cushions: 2 단계, 이미지 3개 중 2개 SteelSeries Arctis 1 Wireless Headset Teardown, Remove Ear Cushions: 2 단계, 이미지 3개 중 3개
    • Let's start on the right side
    • Take off the ear cushions.
  3. SteelSeries Arctis 1 Wireless Headset Teardown, Disassembly: 3 단계, 이미지 1개 중 1개
    • Remove this small plastic piece.
  4. SteelSeries Arctis 1 Wireless Headset Teardown: 4 단계, 이미지 2개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown: 4 단계, 이미지 2개 중 2개
    • Remove the piece under the top of the headphone
    • It should look like this when you are done
  5. SteelSeries Arctis 1 Wireless Headset Teardown: 5 단계, 이미지 2개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown: 5 단계, 이미지 2개 중 2개
    • Time for the fun part
    • Take out the three Phillips screws with a Phillips #000 screwdriver
  6. SteelSeries Arctis 1 Wireless Headset Teardown: 6 단계, 이미지 2개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown: 6 단계, 이미지 2개 중 2개
    • CAREFULLY pull apart the two halves
    • There is still a wire connecting the two halves. Do not pull straight up.
  7. SteelSeries Arctis 1 Wireless Headset Teardown: 7 단계, 이미지 3개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown: 7 단계, 이미지 3개 중 2개 SteelSeries Arctis 1 Wireless Headset Teardown: 7 단계, 이미지 3개 중 3개
    • Let's get a closer look at these components.
    • Be careful to not damage the battery. If the battery is inflated or otherwise damaged, responsibly dispose of the battery.
    • Repeat steps 2-4 on the left side.
  8. SteelSeries Arctis 1 Wireless Headset Teardown: 9 단계, 이미지 1개 중 1개
    • Take out the three Torx Security screws with a size 6 screwdriver
  9. SteelSeries Arctis 1 Wireless Headset Teardown: 10 단계, 이미지 2개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown: 10 단계, 이미지 2개 중 2개
    • Carefully separate the two sides
    • Again, there is a wire connecting both sides. Be careful to not break the connections.
    • The wires on the board are fragile. I accidentally pulled one off while reassembling the headset. I guess I have some soldering to do :(
  10. SteelSeries Arctis 1 Wireless Headset Teardown: 11 단계, 이미지 3개 중 1개 SteelSeries Arctis 1 Wireless Headset Teardown: 11 단계, 이미지 3개 중 2개 SteelSeries Arctis 1 Wireless Headset Teardown: 11 단계, 이미지 3개 중 3개
    • Again, let's get a closer look.
  11. SteelSeries Arctis 1 Wireless Headset Teardown, Conclusion: 12 단계, 이미지 1개 중 1개
    • Thank you for reading. As mentioned above, this is my first guide, so please feel free to make suggestions or list inaccuracies. Thank you!
작성자
1다른 기여자 명과 함께
BC279
회원 가입일: 02/06/24
205 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 61
전체 시간: 303
