WARNING: Do NOT consume strawberry after this!
필요한 것
So we heard rumors that we need to remove this seed to gain access to the "guts" of the strawberry.
Removing it, It shows that the rumor was False. (Don't count on rumors kids!)
이 단계에 사용된 도구:Tweezers$4.99
We found our first clue.
Use our tweezers, we can Forcefully remove the data connector.
With no avail, No way of getting in without any damage.
Repairability - 3
You can't open it without damaging it... THUS you can't fix the internals of it. only the seeds on the outside.
But the seeds do most of the work
댓글 17개
Amazing!!!!!!!!!!!!😂
HelloMacOS - 답글
Very little detail in this tear down, you should at least confirm that the casing's colour is true and genuine RAL3018 (Google it!), or #fc5a8d if you want to be geeky. Also important: How long does it take, without ANY usage whatsoever, before it becomes unusable due to lack of any updates?
🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣 lol
is this teardown the same for a raspberry? Asking for a friend..
