주요 콘텐츠로 건너뛰기
Huawei Mate 10 Pro Teardown
18 단계
Huawei Mate 10 Pro Teardown: 0 단계, 이미지 3개 중 1개 Huawei Mate 10 Pro Teardown: 0 단계, 이미지 3개 중 2개 Huawei Mate 10 Pro Teardown: 0 단계, 이미지 3개 중 3개
  • When it comes to the front-facing camera, we're not quite so pleased—it's very tightly secured in the midframe of the Mate 10 Pro. It wiggles a little, but removing it cleanly is going to be a challenge. So we focus on the display first.
  • But getting in between the display and the frame also looks to be a near-impossible task. No amount of heating, pulling, or prying saw any success. The front panel is glued tight and the tolerances are so small that there is simply no gap.
  • Our only chance is the hole in the midframe for the dual camera. And after using most of the wedging arsenal starting with a Halberd Spudger to an Opening Tool to a regular Spudger we end up with a metal Spudger. And finally a small gap opens up.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
