주요 콘텐츠로 건너뛰기
Microsoft Surface Studio Teardown
7 단계
Microsoft Surface Studio Teardown: 0 단계, 이미지 3개 중 1개 Microsoft Surface Studio Teardown: 0 단계, 이미지 3개 중 2개 Microsoft Surface Studio Teardown: 0 단계, 이미지 3개 중 3개
  • Dig in! We start with the high-powered half of this machine's hybrid storage: a standard, removable, 64 GB SanDisk Z400s M.2 SSD. And on board we find:
  • SanDisk 05466 032G 32 GB NAND flash storage module (x2 for a total of 64 GB)
  • Silicon Motion SM2246XT SATA III 6 Gb/s DRAM-less SSD Controller
  • Texas Instruments power management
  • Amusingly, someone must have decided it'd be better to slap down two 32 GB chips (perhaps leaving room for the 128 GB models), rather than four 16 GB chips—hence this pair of empty solder pads.
  • If you happen to have a couple flash storage modules and a hot air rework station lying around, the SSD controller should happily take up to four NAND flash devices.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
