주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Two beeps and black screen.
I have the same problem as Angela but my screen is always black, when I try to reset it (by holding the menu and select button for 6sec) it just powers off and back on but still gives the black screen. Then it beebs 2 times, just like Angela's I suppose. I just tried to reset it via iTunes but it still shows a black screen. I can hear the clicks when I use the click wheel. What do I do ?
Greetz James
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
My iPod will not turn on I put it on the changer an it beeps 2 times dose that mean its changing
의
댓글 달기
답변 1개
선택된 해법
jamesschelfaut, there are a few possibilities, but they all require you to disassemble your iPod. It could be loose ribbon cables, corroded connectors, a bad LCD and/or bad backlight circuit. I would check it in that order. Here are the guides to work on it. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jamesschelfaut 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 43
전체 시간: 9,849
