주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
질문 마감됨
dropped in water for 2 seconds dried it off.
Then put in microwave with a paper towel around it, it was in there for 2 seconds, However it still works but is slow retrieving when away from wifi. Phone calls are only when there is a good signal and it gets hot. Is there anything I can do to fix?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Connie, you microwaved your phone?
댓글 달기
답변 1개
선택된 답변
Connie, the first step I recommend is that you stop using it all together for now. The more you try to start it and to use it, the more you can damage. You definitely want to clean it properly. Use this guide to get it cleaned. It is written for a 3G but applies to your phone as well. Next thing to do is to replace the battery after that, reassemble and re-evaluate. It is possible that your battery is shortened, or the the power management IC is heating up. I am also not sure about using microwaves on the SMD components.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 417
