주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
Procedure on how to clean the Logic Board with isopropyl alcohol?
I have a MacBook Pro 13 2011, how I proceed with cleaning the logic board which was subject to water damage?
And how do you precede with cleaning? Using cloth or how?
Saw a topic on this page Cleaning a logic board......
Thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
Here's the guide for doing this: Electronics Water Damage
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Aslamualikum dear brother i used mother bord cliner fine product
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello Brother can you pls help,need advice
댓글 달기
Genius Guy, recommend you first open your system and get 99% alcohol to clean the board, dont be scare to take a pane with alcohol and clean the board using a tooth brush getting wet the board it will be ok for Apple boards but not for pcs, leave it for 20 mins, alcohol is acting under chips, then blow it up with regular compressed air, if you are in a hurry blow it up after with hot air, make sure you dont create static electricity, then wait for one hour inspect board again before turn the computer on again.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
HI need help , i spill hot milk in to mother board , if i clean as u said its will work and won't damage the board.
댓글 달기
답변을 추가하세요
Martins Strobinders 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 30,360
