will not connect to a wireless network
How do I get my wireless hp printer to connect to a wireless network?
좋은 질문입니까?
좋은 질문입니까?
try this steps click on the link below.
이 답변이 도움이 되었나요?
i will recommend to follow these steps to - make sure you have the right password of your wi -fi than go to the settings and uninstall the printer driver from the computer and download it from hp website and than install it again . check for any settings issue and you can also try to connect using WPS key for more information you can go to hp http://www8.hp.com/us/en/contact-hp/supp...and once you got it fixed restart printer and computer and print it again to make sure
이 답변이 도움이 되었나요?
Make sure you install the cd correctly and if nothing remove printer from devices and printers and add a new one and have it find it on the wireless.
이 답변이 도움이 되었나요?
If its easily possible then open the printer menu or follow the on booklet instruction to perform a factory reset. Once the reset is done then insert the installation disc and follow the on screen instruction which shall hopefully fix your problem. Good Luck
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 5
지난 30일: 25
전체 시간: 9,234
댓글 2개
Dors ont conect
Anouc Mayr 의
Je ne peux imprimer pas de conception avec hp
Anouc Mayr 의
