주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Question about reball skywork chip
is there thermal grease between both parts of the chip?
or is it done by cleaning the gold shining surface and reball it?
http://cdn.smartphone-parts.com/images/T...
got the same problem with the chip, it broke into pieces
Skyworks SKY77541 module soldering
in the meantime, the new chip arrived and I will try to solder this
desolder the nonfunctioning chip. there seems to be only solder on the outside. but what about the contact sufaces in the middle?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Thx for information oldturkey
think my chip is broke into two pieces :(
Unusual. Take a couple of images and post them with your original question, lets see:-)
okay
I have not reballed already because I'm not sure if the big surfaces are coated with solder or with something else?
has anyone had experience with it already?
댓글 달기
답변 1개
가장 유용한 답변
There is only one part. Your image shows the front and back of the chip. Here are some great instructions about reballing a BGA. Also check this video, different chip, same idea. The stencils for a reball are available at places like this. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 595
