주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore Elite HE3는 Kenmore의 세탁기입니다. Whirlpool Duet과 동일한 모델입니다.
F Code on Machine, wont drain
I an getting a F Code, just F no numbers. The clothes are soaked. I unplugged the machine for an hour and it hasn't changed anything. please help me fix this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 2개
My washer had just. Started. It was filling when I got this code. Where is the location of the filters?
의 공유
@christinek94951
What is the model number of the washer?
Did you read the answer below, posted on 22 Nov. 2014 regarding how to check if it is a two part code or not? It may not just be a single "F" code
의 공유
댓글 달기
답변 5개
가장 유용한 답변
The cold water goes through a mesh screen and often gets clogged. The code usually goes off during the begging of the rinse cycle or at the end. This is when the cold water is most commenly used. YOu have to clean this screen. This is the second time we have had to clean it. The first time with an appliance tech, which cost us close to $100 to do. Now, we will do it ourselves. You just find open up the front, take out the screen when you find it and either clean it with vinegar water or our service tech used muriatic acid.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Did you try pushing/holding the pause/cancel button and then pushing the drain cycle setting button? That is what I did and the washer drained and completed the cycle. The clothes are fine. I don't know what is going to happen next time though.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
id go with cleaning of the filter ...if the front wont do it >>>>I hear there's one also in the back >>>????
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Update to previous response, the error code is a little tricky to read it displays the "F " first and then alternatively flashes the second part of the code like "06" which you may mistaken for how many minutes are left. A common code for your issue might be F06 when combining the two parts of the code. A washer stopping just before the high spin cycle could indicate a MCU board issue, bad connection to the board in the top of the machine, bad connectors or even a motor issue. Having the correct code will help narrow down your particular issue.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It is F06 code belt is good machine drains but will not spin
의 공유
@bartcorcoran
What is the model number of your washing machine?
의 공유
댓글 달기
$316.66 to replace drain pump / motor assembly is a bad omen because of the 666.
Sears Kenmore Elite model 42822 purchased new in 2003 cost around $1000.
Chat with Sears is awesome. Here is a link to replace part yourself:
http://www.searspartsdirect.com/repair-g...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Susan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 95
전체 시간: 69,148
