주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson Xperia Mini Pro SK17i는 3인치 화면, 슬라이드식 키보드, 교체 가능한 배터리를 탑재하고 있습니다. 2011년 8월에 출시되었습니다.
Backspace is too sensitive :-(
My primary situation:
The keyboard is generally working fine but the backspace only needs a fine touch not a complete depress. That means that it will delete half a line in no time when touched. It is placed slightly lower than the rest of the keys but it still has the "click"-sound and -feeling like the rest of the keyboard.
I got the phone in dec. 2011 and it has been used moderately since then. I'm not a heavy text'er or anything like that.
My question (for a solution):
The SK17i tear down does not fully show the parts of the keyboard. Is there a rubber mat between the keyboards outer skin and the contacts?
Is the contruction similar to that of a remote control?
Will I need a whole new keyboard (it's danish)?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
Jesper if you are referring to the "domesheet", yes it does have one. You can replace the domesheet, but it sounds like you are needing a new keypad.
이미지
이미지
The keypad is on the back side of the main board. The domesheet lays over it.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
What is the PCB shown at the bottom photo?
It could be difficult to find a danish keyboard... :-/
의 공유
I attached an image to the original answer to show that it is the backside of your main board. I did a quick (very quick ;) search and only found a QWERTY keyboard on ebay. A danish one may require a bit more of a search.
의 공유
Danish keyboards have QWERTY-layout too, but we have some extra letters (æøå)... :-)
So I will need a new main board?
의 공유
A new keyboard should work and is probably easier (not meaning easy) than the board. You could try and disassemble it and take a look and see if you can isolate the problem.
의 공유
댓글 달기
I have the same problem with my Xperia Mini Pro, "d" letter in little touch is written cycled again and again. Broken was the dome sheet under keyboard. I have replaced firstly keypad, but all was bad as before, after changing dome sheet is all working now fine :-)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jesper 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 1,032
