주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
블랙 핀스트라이프 색상의 Skullcandy Skullcrushers 서브우퍼 스테레오 헤드폰은 음악을 머릿속으로 직접 전달합니다! 강력한 이 헤드폰은 조절 가능한 인라인 베이스 앰프와 업계 최초로 내장된 진동 서브우퍼 스피커 드라이버를 특징으로 합니다. 인라인 조절 휠을 사용하여 베이스 효과의 강도를 조절할 수 있습니다.
both subs are not working
When i move the wires around they go on and turn off when i move it and i have opened them up and every thing looks fine i do not no what to do.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Adam Thompson,"i move the wires around they go on and turn off when i move it" indicates either a bad solder connection or broken wires. You have not told us where you wiggle the wires to make it work. If it is by the audio connector, replace it using this guide. If it is by the bass amplifier, open it up and take a look at the solder connections on there. I attached a few images that should help you to identify the wires and connections.
이미지
이미지
Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
i am moved the wires where the speakers connect i have looked where they connect there and it looks to have no connection problems there
Sounds like a bad bass amp. Check the components on there with a multimeter and see if you can figure out what failed.
댓글 달기
When I had the same problem as stated above, I often had to tap on the head phone that had the bass control installed to bring the bass back to my normal listening level. I finally decided to see if I could re-mediate this problem for once and for all. I remove the amplifier and re-soldered the bass control tabs, the eighth inch audio input jack tabs and the cable wires that connect to the amplifier board. Now the bass does not drift in and out when I'm listening to music.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Adam Thompson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 4,489
