주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
7인치 스크린을 탑재한 Google 브랜드 태블릿입니다. 기기 수리에는 분해용 도구와 스크루드라이버만 있으면 됩니다. 모델 번호: ME370T.
Where Can I Find Replacement Micro USB Port?
I have found some general ports on Ebay, but I don't know if I need a specific type, or if I replace the entire USB/Headphone Jack assembly. I have hunted several sites, Ebay, Amazon, iFixit, DIY and a lot of forums for this information, and I'm just about to give up and hand it to my PC repair guy or Best Buy (which I reallllllly don't want to do!).
Does anyone know a great place I can find replacement parts for this confounded tablet!?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
do not forget britain websites, you pay in liras and the have lots of replacement parts online
댓글 달기
답변 11개
가장 유용한 답변
jonathanchiestand, it does most certainly look like a standard micro USB port, and I would be checking with places like Mouser.com or Digikey.com. Ultimately I would replace the I/O assembly cable. That is readily available, won't require any soldering and you won't have to hunt for it. It is available at places like this and others, I am sure. The guide from here should help you with that. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
oldturkey03 , What is the RS Component part number you used?
mrholidayinnexpress, sorry RS is really not a place I deal with. So I do not have their part number.
What if you have a 2013 model? Does anyone know a good place to find the parts since the USB and Audio Jack are seperate pieces?
댓글 달기
part number ME370T_IO_FPC R1.2 for nexus 7 gen 1
http://www.asusparts.eu/en/partfinder/As...
about $43.00 brand new include shipping
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I managed to find one from a seller on Amazon UK.
http://www.amazon.co.uk/Asus-Nexus-Repla...
Its actually better than the original as the metal is stronger and has been joined together better. Took me about 10 minutes to solder and fitted perfectly. Finally can charge my Nexus again :D
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It's practically impossible to find a replacement I/O assembly cable.
My daughter broke her USB connector and I had to replace it.
Even though it's a standard micro USB connector, the PCB housing is pretty special.
I managed to find a somewhat similar housing with RS components, and replace it, but it took some creative soldering.
I don't recommend this though, if you're not experienced with fine pitch rework soldering, as the procedure does require some skill.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Sorry oldturkey03, I meant to direct the inquiry to Thomas.
So Thomas, can you refer me to the part number you used that you mentioned you acquired from RS Components?
Thanks
댓글 달기
http://www.etradesupply.com/oem-asus-goo...
Much more for the same price
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I purchased a replacement I/O assembly for my wife's Nexus 7 a few weeks ago on Ebay. It was from foxpcparts. I liked them because they shipped from Michigan (I'm in the USA). They aren't selling any today, but there are a few others that ship from China and Hong Kong. Just search for:
"nexus 7" usb charger port
By the way, it works great. The nexus charges much faster and the charger stays plugged in more reliably (not perfectly, but definitely better).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Here is the digikey part number for the part I will use for my replacement. 1554266-1
http://www.digikey.com/product-detail/en...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I used the same part with some success. Thank you for the reference Willei. Details below.
댓글 달기
The TE Connectivity 1554266-1 (Digikey A107905CT-ND) is a very close match, but the pins are a bit too short. I was able to bridge the gap with solder but I doubt it will stand up to much abuse.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This link really helped fixing my wife's tablet. I bought the connector from ebay, shipping was free. It was really quick and came in a week. I got the old one removed and soldered the new one. The tablet started charging and working like before.
Steps in this thread really helped in getting the device fixed.
http://www.ebay.com/itm/221427451048?ssP...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
What if you have a Nexus 7 2013 model? The audio jack and USB are seperate parts in the newer one. Anyone know where I can find parts?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It works! Check out the pictures below.
https://plus.google.com/photos/114684441...
I purchased the micro USB port below and had some success. The spacing between the anchors was off so I had to cut them off and simply surface mount solder the USB port on. The purchased port is not very close to the OEM version but it did the job.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jonathanchiestand 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 16
전체 시간: 47,595
