주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Why is my device not charging?
I recently purchased an iPhone 4 that has had water damage. After having a friend who repairs all sorts of apple products look at it, he though just the battery need replaced due to the corrosion on the terminals. After ordering and replacing the battery i plugged phone in to iTunes and factory reset it. Shortly after i noticed the phone was not taking a charge, although it was plugged in and the device recognized that. Thinking i had a faulty battery i replaced it a second time and had the same results. The device syncs and transfers data just like any other iPhone would just doesn't charge. I have even tried multiple transfer cables, different computers and different wall outlets. No luck. both the dock water damage indicator and the one inside on the lower half (beside battery connector cable) have turned red. I am wondering if replacing the dock connector on the phone will solve my problem, or if my phone is shot. I cant see it being much more because everything works like it is supposed to other than it doesn't charge.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
trevor, the very first thing that you should do is to properly clean your board. If you have "due to the corrosion on the terminals" you will also have it somewhere else. Use this guide to clean your phone. It was written for a 3G but all the points are still pertinent to your phone. While you clean it, check your board for any missing, or burned components. You'll need a magnifying source for that:-) After that, replace the dock connector. There are plenty of other reasons while your phone may not charge, all of them are no fun. There are plenty of components that regulate the charging function, starting with the PMIC, and none are easy fixes. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hey mate,
You will most likely have to replace the dock connector. You can purchase them for relatively cheap (around 15 dollars shipped.) I have done it myself and it is not a particularly difficult replacement - following the guide linked above is a good step as well.
Cheers.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
trevor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 206
