Where to get replacement plugs for logic board wires?
Greetings,
Where to get replacement plugs for logic board wires? The logic board replacement guide did not specify how to unplug them, and I pulled the wires out of and broke one of the speaker plugs and the backlight plug.
Also, how do I tell in what order the wires go into the plug?
Thanks
좋은 질문 입니까?
댓글 5개
Charles Kensington, a few things you want to start off with. what are the last three digits of your serial number? this will allow us to properly identify your computer. Next you want to post a couple of images of the damaged connectors. That way, we can see what you see.
oldturkey03 의
Serial # Z62
The plugs are completely broken off the end of the wires coming from the backlight. So it is just four lose black wires.
The same with the speaker wire. No plug. Just a black wire and a red wire.
Charles Kensington 의
Apple MacBook "Core 2 Duo" 2.0 13" (White-SR) Specs
Identifiers: Late 2007 - MB061LL/B - MacBook3,1 - A1181 - 2200
mayer 의
So the backlight wire and the speaker wires have a broken connector. the receptacle on the logic board are still okay, it is just the ends of the cable that are broken?
oldturkey03 의
"So the backlight wire and the speaker wires have a broken connector. the receptacle on the logic board are still okay, it is just the ends of the cable that are broken?"
Correct.
