주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4.3인치 터치스크린과 Bluetooth를 탑재한 포켓 사이즈 GPS 수신기.
Back removal to replace battery
I would like to remove the back cover on my Go 720 but have had no luck to date. need help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
ron, follow the instructions for a battery replacement, they will show you how to disassemble your Go720. Here is a video on it and here are the written instructions. Hope you will take lots of pictures and create a guide for this ;-) Good Luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
when trying to open a device first look for any visible screws, then check and see if screws are hidden (under stickers or rubber feet). to check under stickers without removing the sticker just run your finger or a tool over the sticker and see if you find a round dip where a screw will be.
last will be clips under a frame, use a pry tool to lift the edges till you hear the clips pop and release and work your way around. if you dont have a pry tool you can use a butter knife to a small chisel but i recommend something that hard plastic to not scratch or damage anything.
hope this was helpful, good luck and reply back with your results.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ron 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 17
전체 시간: 1,403
