주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Galaxy 551은 2010년 Samsung에서 출시한 슬레이트형/QWERTY Android 스마트폰입니다. 모델 번호 GT-i5510으로 식별할 수 있습니다.
Phone screen is black
I droped my phone a couple of hours ago in the toilet. I took it out Immediately, dryed it off and let it dry out after I took it apart. I put it back together and it turned on but the touc screen wouldn't work so I took it apart and let it dry a little longer. I put if back together a hour or so later and it turns on but the screen goes black and I can still here the sounds of incoming text messages. How can I fix this??????
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
Kalie, treat it just like any other device with water damage. The very first thing you want to do, is to no longer charge your phone, or to try and turn it on. This may lead to further damage. Remove the battery and disassemble your phone. Clean every part, including the connectors on the board as well as on the cabled with 90%+ isopropyl alcohol and a soft brush. Be diligent about it and clean it well. This does not mean to scrub hard, just rinse in alcohol often. Check for any burned looking or missing components.After that reassemble it and re-evaluate.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Thanks! Now it turns on but the touch screen won't work! Why?
의 공유
You still want to clean it :-) could be just a shortened digitizer or a shortened touchscreen IC.
의 공유
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
Give it to him for repair XD
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kalie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 899
