주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Splendor라고도 알려져 있으며, LG Optimus L7의 변형 모델입니다. 통신사에 따라 LG Snapshot 또는 Swift L7이라는 모델명(US730 및 LG730)으로 불리기도 합니다.
How Do I install a LG730 LCD Display Screen?
I just replaced my screen on my LG730, now I am waiting for my new LCD screen to arrive. I am wondering, how do I install it? I have a rough idea, but never had to do it before. I spent time on the internet and could not find much. Does anyone have advice?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 2개
Well I should have clarified. I Replaced the touch screen, which had a few spider web cracks in it. I also damaged the LCD screen, I do not know how to Take out, and put in the new LCD screen, at least with out damaging anything.
Oh nevermind, I did a little tinkering around, and got it all situated, thanks for the help though man, I'll accent your answer.
댓글 달기
답변 1개
선택된 해법
Zack Borgen, I am a bit confused. You said that you replaced the screen, but now you are wondering how to install it. Did you check my answer from here:"
Take apart the battery cover using notch below
이미지
Take apart the battery and remove screw (12 point)
이미지
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
이미지
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
이미지
3. Remover the Bracket Camera to upper
이미지
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
이미지
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I'll take another look at my LCD, but it does not just come off like the instructions show. So I'm sure I'm reading something wrong
Thank you for accepting my answer. If you need to take a look at the manual, let me know. My email address is in my profile.
댓글 달기
답변을 추가하세요
Zack Borgen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,854
