주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.7 GHz 듀얼 코어 인텔 프로세서 (최대 2.6 GHz 터보 부스트), 3 MB 공유 L3 캐시
upgrade ssd in MacBook air
can I upgrade the ssd in my MBA with a MyDigitalSSD 240GB (256GB) BP4 50mm SATA III 6G mSATA SSD Solid State Drive - MDMS-BP4-240 ??
If not what are the options for ssd upgrade?
Thx
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
AFAIK NO - the drive is Proprietary* (6 Gb/s)- (MLC) High-Performance Sync-NAND. Apple does not intend for one to upgrade the storage after purchase, OWC has found a 3rd party solution. OWC also has an external case for your old Flash Drive so you can transfer (clone) your files, and keep it for backup (the used value of these drives will probably not be high due to a very limited market).
If this Answer is helpful please remember to return and mark it Accepted.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
It does look like OWC has several solutions/options including 240 GB and 480 GB, and, Amazon sells Transcend 240 GB, 480 GB and 960 GB ! Thanks for the tip!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Why would you like to spend a lot of money on a slow OWC SSD? Why not buy an adapter from Aliexpress for 2,5 USD and buy an industry-standard SSD. (Also for any other non soldered SSD)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
While someone could argue that with a PCIe/NVMe interfaced drive that's not even possible here as this drive is a custom mSATA drive. The I/O speed can't exceed 6.0 Gb/s as thats the limits of the I/O connection!
I still think going with a real Apple, OWC or Transcend SSD drive is still better given the problems you face trying to force fit these fangled adapters and M.2 SSD. I've got a drawer full of dead adapters and M.2 SSD's!
Review this for more details: he Ultimate Guide to Apple’s Proprietary SSDs
의
댓글 달기
답변을 추가하세요
timdruma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 2,661
