주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note II는 대형 디스플레이와 내장형 스타일러스를 최적화한 소프트웨어를 탑재한 스마트폰입니다.
Not registered to Network
I bought this unlocked Samsung Galaxy Note II about 9 months ago, and it worked perfectly. All of sudden, it stopped recognizing the network. It keeps saying that it's unable to connect, but it can recognize T-mobile signals. It looks like the phone knows that there is a signal but is unable to connect to the network. Everything on this phone has worked very well other than this network problem. I can use WiFi perfectly, but I cannot make or receive calls. Would you please help me? Thank you so much.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 175
댓글 12개
same problem, really frustating!
의 공유
Aya Drilon' link it's the most helpful.
의 공유
my matter galaxy note 4 not registered on network please my matte solved
의 공유
me too its just too devastating
의 공유
For T-Mobile, have you contacted them to see if a new SIM is needed? Normally they swap SIMs for little to no charge.
의 공유
댓글 7개 더보기
댓글 달기
답변 11개
선택된 해법
hello, i have found a solution that works here it is http://www.technobezz.com/fix-samsung-ga...
이 답변이 도움이 되었나요?
점수 16
댓글 1개:
i) If Your E5377T Device shows 0 attempts 10
의 공유
댓글 달기
very simple:
Go to [settings]-[More settings]- [mobile networks]- [network mode] and then select [GSM/WCDMA (auto mode)]
이 답변이 도움이 되었나요?
점수 13
댓글 4개:
this helped...thanks a lot
의 공유
this helped. thanks a lot!
의 공유
not working my note 2 n7100 4.4.2 is already gsm/wcdma outo mode.
의 공유
My Note 2 isn't connected to a provider. My wifi connection is strong but it still says"no Internet connection"...I just want to use on WiFi not as a phone...
의 공유
댓글 달기
Easiest, but not likely: your SIM is shifted or the contact continuity has degraded. Shut off phone, pull out sim and check condition of contacts on SIM. I've had to clean a really old and corroded SIM with the eraser on a pencil before. I stuck the center of the eraser over each contact pad on the SIM and gave a dozen or so back-forth twists to rub the oxide buildup away, repeating in a grid pattern to cover the entirety of the contacts. Once done, blow off any loose debris and pop the SIM back in and give it a go., Pay attention to SIM pad to phone contact alignment, particularly if you're using a cut down full size SIM, also.
IF that doesn't work, there's another common, but really annoying firmware corruption issue that occurs somewhat often:
1. Go to the phone dialer and enter *#*#4636#*#* to pull up the hidden testing menu.(4636="INFO") and the menu should pop up as soon as you press the last * key, without having to hit dial.
2. pick first menu option "Phone information"
3. The first line on the phone info menu should be IMEI. Compare it to the IMEI printed on the label under the battery.
If they don't match, it's likely that the IMEI from the menu got overwritten or corrupted somehow.
At boot, Your kernel pulls a config file from a factory-programmed, device-specific config file in the EFS folder on the root of your internal stoirage. If the EFS has bad info, the IMEI will get set to a single, specific value that is the same on every GN2. I don't remember the valyue offhand, but it's mentioned on XDA a few times in the forums.
Hopefully, you have a backup of default and proper EFS partition handy that you can restore in recovery mode.
Barring the existence of a valid backup, I think there are a few, complex methods to flash a generic stock image via ODIN, then you can go into root explorer and manually update the file(s) with the appropriate values.
I had this happen anout 2 weeks ago and freaked out because I couldn't find an EFS image backup in CWM recovery. After about a day of dinking around with no success, I realized I had a TWRP backup from when I first rooted the phone, so I restored just the EFS partition image via the advancved backup menu in the PhilZ CWM recovery.
After flashing and rebooting, the SIM got provisioned on the network, but my phone app and gvoice kept crashing. I updated my to a later, fresh version after doing a cache/dalvik/factory wipe from recovery and it's back 100% now.
Update
Make sure you're flipping the # and * characters on both ends:
*#*#4636#*#*
start: * before #
end: # before *
이 답변이 도움이 되었나요?
점수 8
댓글 2개:
IMEI is not the same on back of my phone. Can you please explain me more, if I can fix it without root, or I have to root it, please?
Thank you
의 공유
after flashing so many ROM, my device N7100 is factory mode on and not registered on network Message is coming. i dont have any backup of EFS also, bymistake i format that also.please help in this case
의 공유
댓글 달기
Bro here is the solution for your device. Do refer the below link.
Solution for Not Register On Network
이 답변이 도움이 되었나요?
점수 5
댓글 달기
*#0*#
this is for the tmobile version
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
What more do u do when u enter this code
의 공유
댓글 달기
There are a lot of reasons you may be facing the not registered on network problem . These are
1 Nulled IMEI Number
2 No Service
3 Unknown Baseband
4 Outdated Firmware
5 Radio is off
You can check your IMEI number by dialling * # 0 6 # , you will see 0000 or nulled if it's corrupted.
If you have an Unknown baseband then i suggest your to backup and restore your EFS Folder.This folder contains all the information about your phone.
Simply go to settings , then go to about, then hit the update button.This will update you to an higher OS version
If your radio is off , dial *#*#4636#*#* . Then click Phone Information.Run a quick Ping. After, Turn Radio OFF/ON
I found all the information on - http://www.technobezz.com/fix-samsung-ga...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
의 공유
댓글 달기
I solved this problem (No register Network)by using SPT box.
1.reset default EFS.
2.writing super imei.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Is it not taking any network signal or it seldom takes and sometimes doesn't take? If it is not at all connecting to any network then it can be software issue but if it is switching between getting or not getting signals then it be a hardware issue aswell
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Tengo un s3 i 747, lo actualice a androi 5.1.1 y ahorra me dice No se inserto Ninguna Tarjeta SIM, pero si recibe msj y llamadas, no me levanta datos. y el APN dice que La configuracion del nombre de punto de acceso no esta disponible para este dispositivo, ¿que hago? por favor ayudenme.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Solving “Not Registered on Network” on Android?
Method 1: Restart the Android
Method 2: Turn Flight Mode on/off
Method 3: Toggle SIM off/on
Method 4:LTE/VoLTE Connection switching
Method 5: Remove SIM Card and Re-insert.
Method 6: Reset Network Settings
Method 7: Manual Network Mode
Method 8: Clear Android Cache
Method 9: Enter Service Mode (Samsung phone)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
SOLUTION TO IMEI PROBLEM https://www.youtube.com/watch?v=AzTkb_qn...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My mobile screen is often showing mis call at 05.00 hrs on screen
의 공유
댓글 달기
답변을 추가하세요
Banafsheh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 63
전체 시간: 258,568
