주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
문과 창문의 보수 및 해제 안내서입니다.
How to install a window to replace AC unit?
Hi Folks,
Finally got around to removing a heavy old built in Air conditioner unit from my living room.
http://flic.kr/p/ggN4a9
이미지
I'd like to install a window that can be opened to let the breeze flow. Could anyone let me know where to start?
Thank you!
Jacob
Update
Thanks for the support so far. Working on removing the metal frame the air conditioner was housed in this morning. At first nice and quietly with the bolt cutters as not to disturb the neighborhood. Then, more successfully using the angle grinder to cut away the box.
http://m.flickr.com/#/photos/slugworth/1...
이미지
이미지
이미지
이미지
Update
The opening is roughly 26.5 by 18.5.
Here is a view from the outside.
And a look from inside.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
How about a photo from the other side?
의
Jacob, couple more pics will definitely help. BTW love the architecture, real brisk and a solid wall, excellent!!!!
의
Jacob, that is a definite ifixit job:-) Keep us informed about your progress. Still wondering what the window opening looks like from the inside and outside with the AC removed. what are the dimension of the opening?
의
The base of the AC unit was resting on the roof below. Some tar was keeping it in place. I used a crowbar aka "Sparticus" to pry up the final pieces.
의
댓글 달기
답변 2개
선택된 해법
Jacob, great demolishing job:-)! anyhow, at this time you will have to repair the brick work in the opening. Use what looks like a top beam in your pictures as the lentil. Get some pressure treated lumber and fasten it with anchor bolts around the window opening. That will give you something to mount the new window to. I would check sites like this for installation instruction. Of course, not knowing where you live, you also want to make sure that you have proper drainage away from the window etc. Follow your local building code. It is a relatively small opening, so keep the framing reasonable. The attached images shows how it should be done:-)Hope this helps, good luck.
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Do a Google search for transom+window and images for some ideas.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jacob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 41
전체 시간: 5,071
