주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1999년부터 2004년까지 생산된 2세대 북미형 Honda Odyssey에 대한 수리 안내서 및 정보입니다.
I need the car radio code
Hi I change my battery on my Honda 2004 Odyssey. I need the car radio code. The radio serial number is [serial number removed for privacy]. and the vin number is [VIN removed for privacy] Thank you. My email is [email removed for privacy]
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
I did the same thing my serial number is 2417 my vin is 1hgem22963l00904 my email is corley937@gmail.com
의 공유
Hey Gregory, you can actually get a radio code here: https://radiocodevault.com/honda
Hope it helps mate
의 공유
댓글 달기
답변 3개
선택된 해법
skyppy103, look on the side of the glove box or behind the ash tray for a sticker with a 5 digit code .If its not there then you will need to remove the radio to get the serial number and either call your Honda Dealer for a new number or post it back. If it is a 2002 or newer try this
Turn your radio off.
Turn key to the ON position. Do not start, just leave ignition in ON position.
Press and hold the numbers 1 and 6 on your radio with one hand.
Using your other hand, turn the radio on while keeping 1 and 6 pressed.
Ten characters will appear on the screen, usually alphanumeric. Write down all the numbers you see.
Now you can either drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. Or you might want to try this one online. https://radio-navicode.honda.com/
이 답변이 도움이 되었나요?
점수 5
댓글 4개:
Worked!! Thanks oh it was in the glove box
의 공유
Hi i changed my battery in my car and i now needs the code to my radio i have a 1999 honda accord my serial number is m98k103374
의 공유
Hola,antes que nada buenas tardes, yo compre una Honda odyssey 2003,el problema es que el estéreo está bloqueado y las personas que me la vendieron no saben el código la realidad es que nose que hacer,gracias
의 공유
i nded my radio code for a honda accord 2003
의 공유
댓글 달기
You can find the radio code for your specific car here: https://radiocodevault.com/honda/
They worked for me, and emailed me my radio code in 30 minutes. Should work for you too.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
WORKED thank you a lot!
의 공유
thanku this worked for me
의 공유
댓글 달기
Hi,
I would highly recommened that you visit FreeRadioUnlocking.com
You can find their guide on generating a Honda Odyssey radio code for free here: http://www.freeradiounlocking.com/brands...
I can personally vouch for this website as I've used it to unlock the radio of both my Honda Civic and my wifes Honda Accord and it worked great both times.
I hope this answer helps you out!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Does not work!..... Just a bunch of ads :/
의 공유
댓글 달기
답변을 추가하세요
skyppy103 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 91
전체 시간: 34,458
