주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
T-Mobile G1은 안드로이드 운영 체제(OS)를 탑재하여 출시된 최초의 스마트폰입니다. 2008년 9월에 출시되었습니다.
Why does my camera/camcorder application force close?
I have rooted G1 running the latest Cyanogen 4.2.3.1. Unfortunately, my camera/camcorder app force closes and refuses to open. I have wiped, reformated the SD, restored to stock G1 ROM, even went as far as trying another ROM thats not Cyanogen (*GASP*), but everytime it force closes. I am thinking it might be a hardware problem, but I'm not sure. Help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 5개
Are you running 1.5 or 1.6?
의 공유
I'm running CyanogenMod 4.2.5 which is based off of Donut 1.6.
의 공유
Normally this should be asked as a comment, but I'll hold off on down-voting you since you don't have the rep for commenting.
의 공유
sorry, i'm new, just got the code today, and don't understand this system entirely
의 공유
try reheating the i.c around the camera,i repair phones fyi
의 공유
댓글 달기
답변 5개
가장 유용한 답변
This intrigued me so I went into study mode. All I can say is I do not have an answer. The cam force closes even when phone is restored to T-mob stock configuration?
Help per my reading:
1. http://twitter.com/cyanogen
2. http://wiki.cyanogenmod.com/index.php/Ma...
3. http://forum.xda-developers.com/showthre...
good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
The cam does force close when the phone is restored to stock configuration. I have a feeling that its a hardware related issue at this point.
의 공유
댓글 달기
I'd assume then its a cyanogen bug, the latest ROM is not 100% compatible with 1.6, try a complete restore to the original rom and it should probably work.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
it sounds like it can't find the files in order to run
check and see if you accidentally moved or deleted some of the files
이 답변이 도움이 되었나요?
점수 1
댓글 달기
update software of camera
이 답변이 도움이 되었나요?
점수 0
댓글 달기
After clicking images, images are shown reverse
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Walter Galan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 7,994
