How to fix apple error code 29
how to fix apple error code 29
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
Hi All,
Same for my iPhone 4S. WiFi upgrade to iOS9.3 from 9.2.1 failed/stalled. I then tried connecting to iTunes as the phone was stuck in recovery mode. It still failed about 2/3 of way through and left me with a phone that was not functional.
After 2 hours (over two days) with Apple Tech on Chat they booked my an appointment at the local Apple store. I was not happy as the phone worked perfectly until this upgrade!
Given error 29 is related to the battery or battery connection (by all accounts). The new battery (non Apple) which I installed 3 weeks ago and replaced with an original Apple battery. I also scrubbed the battery connector terminal on the motherboard with a soft toothbrush and rubbing alcohol.
I reconnected the phone to iTunes (old battery) and the upgrade was able to complete. I then replaced the old battery with the new non genuine one I had removed earlier and the phone is working fine.
I don't believe my new battery was faulty nor was there a hardware issue as such, but possibly the iOS9.3 is sensitive to non genuine parts in an old phone!
Good luck if you come across a similar problem as this may help you.
Admiral Adama
이 답변이 도움이 되었나요?
Hi This is exactly what happened to my 4s including an hour chat with Apple Tech and her booking me into local Apple Shop for a mechanical fault find. Rather I took out the non genuine battery and refitted the old genuine , restore then completed and phone worked fine.
Great solution. Perfect! Change battery with original and returns your old (now original).
Can confirm that this trick works. I had huge problems to upgrade from 9.3.4 to 9.3.5. Got error 29 all the time until I got the idea (before I read all these posts actually) to replace my newly replaced battery, with the old one. The upgrade went smoothly with no problem at all with the old original battery. I'll revert to the newer battery after the upgrade...
Brilliant. Thank you. Solved my issue!
Replacing the replacement battery with an OEM one fixed my issue too. One of the really nice features of the 4s was how easy it is to just remove a couple of screws, slide off the back, remove a few more screws, loosen a connector, and just replace the battery. It is too bad that Apple has focused way TOO much on thin is in instead of practical and functional. It is not environmentally friendly when products that have been easily repaired in the past now have everything soldered and glued to so that they are considered disposable when a part breaks :-(.
just fixed my 4S (at least for now) after replacing battery. After plugging in to charger, I got the dreaded plug into iTunes symbol. After trying to restore numerous times to no avail, I plugged back in the old battery. I was than able to do a factory restore. replaced the old battery with the Ifixit battery again and it is working so far.
Hope I don't have to do this again and again....
이 답변이 도움이 되었나요?
the iphone iphone could not be restored unknown occurred (29)
이 답변이 도움이 되었나요?
i got that exact problem. idont know what to do
yes what is this problem
I had this problem on a non jailbroken iphone 4s tried the above to no avail .
Basically if you've exhausted all the other fixes... changing the battery,removing firewall,antivirus,editing host file etc etc. Then check the last line of your itunes restore log if it says something like...'RamrodErrorr domain/3ea: update_gas_gauge: gasgauge_swupdate returned -1' ... Ifixit has the answer and more details here.....
Small component broken from the logic board .
In my case on a (very)close inspection it's a capacitor.. that's missing!?!.
Hope this helps someone as this info took me best part of a week to find!
이 답변이 도움이 되었나요?
I restored iPhone 4s with ipsw 9.3.2 then show error 29
- change battery
- restore again
- succes :)
이 답변이 도움이 되었나요?
thank u very much
thanksssssssssssss
hey bro , i know it needs an oem battery before it fix but is class a battery will work too?
am restoring my iphone 4s with itunes and there was an error 29,
so am asking how to go by it to fix it and the restoring will continue and the iphone 4s will be normal
이 답변이 도움이 되었나요?
Read the posts. You need to temporarily replace the battery with an original Apple one, connect phone to a PC, do the update through iTunes , then replace the Apple battery with yours ( if you want).
이 답변이 도움이 되었나요?
I found my old Iphone 4s battery and i have noticed that the old and the current battery APN is same 616-0579 and 616-0579 but still i replaced the old one to update my iphone but still it got stuck on recovery mode please advice do i need to replace the battery with APN 616-0581 or the problem is not with the battery.
also before replacing the battery i rubbed the clip area with alcohol .
Please help!
이 답변이 도움이 되었나요?
Where can i purchase a new 4s original battery? And how much? Please help me guys. Thnx
이 답변이 도움이 되었나요?
Requirements:
# iOS Device (Mine is 4S, may work for other devices too)
# Windows 10
Steps:
이 답변이 도움이 되었나요?
Same issue, failed ios 9.3 update on an iphone 4s. Replaced new (non Apple ) battery with an original and then the update worked fine through itunes. Could then put other battery back in. Thanks for the tip.
이 답변이 도움이 되었나요?
I will never buy another Apple product! They employ very underhand methods to force people to line their pockets by using their repair services or buying new devices.
이 답변이 도움이 되었나요?
An outdated version of iTunes may be the reason why Error 29 pops up on the screen while you are trying to restore or update your iPhone's iOS with this app. To update to the latest version of iTunes you should open the app and choose the Software Update option from the Apple menu.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 107,912
댓글 4개
My friend recommend this way to fix iOS system problem.
blacchyna66 의
Please do NOT waste your time downloading the link in "this way" from blacchyna66. You will download Wondershare Dr. Fone app. It looks like one can fix their phone by clicking on "More Tools" and "iOS recovery". The trial version will tell you that selecting a ipsw file already downloaded is for registered users. New users think if they take the time to download the file, they can then use iOS recovery. Not so. When the user clicks on "Start Fix", a message that this tool is restricted to registered users only will display. Why not say that up front? I will NEVER buy this program for that reason. It is deceptive and misleading. Part of me wonders if it would work because it may bypass that iTunes software since it seems to restore the software on its own, but I will never find out. Personally, I think it's the battery. I think Apple should be barred from practices like this that make a phone unusable. If the owners wants to use a replacement battery, then just let the owner assume the risk. Why let the battery work all this time and then brick the phone? I no longer have the original battery and am not sure I can get an OEM one.
Pinkpower4 의
Replacing the replacement battery with an OEM one fixed my issue too. One of the really nice features of the 4s was how easy it is to just remove a couple of screws, slide off the back, remove a few more screws, loosen a connector, and just replace the battery. It is too bad that Apple has focused way TOO much on thin is in instead of practical and functional. It is not environmentally friendly when products that have been easily repaired in the past now have everything soldered and glued to so that they are considered disposable when a part breaks :-(. I do not think I would have convinced someone to let me pull the screen off one of the new phones (iphone 5 and up) and hope the screen doesn't break to borrow a battery...
Pinkpower4 의
Huy Bui 의
