주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
하드 드라이브 또는 하드 디스크에 대한 수리 정보입니다. 하드 드라이브는 자기 방식의 데이터 저장 장치입니다. 낮은 비용과 높은 데이터 밀도 덕분에 대부분의 데스크톱, 노트북 및 서버에 사용됩니다.
Compatibility in swapping out the PCB...
Hi all -
So I'm wondering if anyone has any knowledge about swapping out the PCB (printed circuit board) on 1.8" HDD....
I have this Samsung model (Samsung HS16VJX - 1.8" HDD 160GB) where the OEM PCB is a direct to USB port. I need a ZIF drive (yes, for an iPod) and found someone with a PCB for a Samsung HS081HA 80GB 1.8" ZIF Hard Drive. Thought about purchasing it and hoping for the best, but would prefer to have some confidence behind spending the money.
Let me know. Much appreciated!
Jason
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Yeah... that much I knew. I just thought perhaps since they were both 1.8 Samsungs, I had a much better chance of it working. Just wondering if anyone else has had success. Thanks Cris
Jason
의 공유
댓글 달기
답변 3개
선택된 해법
Hi,
you can try it.
But every drive has a memory chip on the PCB that stores unique informations about this certain hard drive. If you buy a PCB from another drive the stored informations may not fit to your drive.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
agreed +
의 공유
댓글 달기
I have successfully received the PCB,I replaced the BIOS chip on the PCB by the original and it has worked perfectly.I was able to retrieve complete information from the hard disk. Wish this can help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I own exactly the same drive (HS16VJX ) and I’m looking for a PCB to salvage data.
@jcarter: it appears you chose @crib’s solution, but it’snot clear wheather it worked for you or not? Did you do as James Yu wrote and replaced the BIOS chip?
Thanks in advance,
Calagan
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jcarter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 2,604
