iPhone 4 keeps searching for signal
My iPhone 4 keeps "searching" for a network. And it doesn't register "No Sim" when I remove this sim. I've opened it up, but I'm not sure if the blue coil is damaged.
좋은 질문입니까?
좋은 질문입니까?
This problem can happen if you disconnect the battery or if the battery get disconnected by it. You can tell if this is what happened because the year will say 1970 or so. The best way to solve this is to connect to WiFi and sync to the correct time. Then, switch airplane mode on/off a few times, remove the SIM card, and power off your iPhone. Reinsert your SIM and that should do it! Good luck with that.
이 답변이 도움이 되었나요?
thank you maaan dz helped sooo much my iphone is ayt
You are welcom
sharing they say is Knowledge..
Brilliant and I didnt even have to do the SIM card removal, sorted with just the WIFI connection and airplane mode turned on and off a couple of times.
Many thanks almost bought a new phone !
u are welcome.. you may hit the "green up" button (helpful) to show ur appreciation ...
great work man!
The coil looks okay, the symptom looks more like a baseband logic or hardware issue.
FYI this is the common procedure to resolve reception issues
If the phone is showing reception issues, try the following
Remove all external accessories to rule out 3rd party accessories that could block or even interfere with the signals
Test the reception on another known good identical phone to rule out coverage issues
Reboot/restore or upgrade the phone software to rule out potential software issues.
If none of the above works, there are probably hardware issues.
I've observed newly powered on iphones constantly display "searching" until the system clock is synchronized with apple servers and airplane mode is cycled. The baseband was stuck on wrong config data because the clock is off. reboot or just recycle the airplane mode should clear it out.
If it still doesn't work, go to settings-general-about to check the IMEI\baseband virsion\ICCID is abailable. Missing IMEI and version means that the baseband is not working, Having these but the ICCID is blank means that the SIM card is not linking with the phone. Both cases are difficult to repair
이 답변이 도움이 되었나요?
Thanks Tom. sadly when I have successfully restored the device to factory settings I get an itunes message 'There is a problem with your phone' which means there is a hardware fault. so now I don't have access to settings. phone is out of warranty and has been opened up so apple cant help there. my network carrier says there is no reason why it shouldn't activate..
I've ruled out the software issue
will try it in another identical phone tomorrow
thanks for your help so far
Thank You!!! That really helped
Love Tom's answer--just wanted to add that it is very easy to coincidentally knock off baseband components when prying up the battery on the logic board side. I bet if you look under magnification you can pinpoint the missing components.
Jess
Thanks Jess...will look for any missing components
Hi Jess, I am your fan! I am very amateur fixing phone yet, since I am trying to fix iphones, you have been my best ever teacher. I am from Brazil and have learned a lot from your youtube videos. BTW, I did a mistake of prying up the battery, and an very very small IC was knocked off the board. I do not have yet the skills for micro soldering and my doubt is: 1) it seems the IC who came off is intact. If so, just resoldering it would fix the problem? 2) Can I pick the same IC from an older iphone and if I am successful to sold it, it would probably fix the problem? Or do I need to change many baseband componets to get the IMEI and Version number back on the GENERAL>etc?
Hello everybody- This thing can happend when you open your iPhone 4S, change the LCD screen or change battery. For me- as I work with iphones the solution what has helped me is simple- first of all go to settins- reset- reset network settings.. Your phone then resets all network settings and 90% of the time your signal comes back as it was! :) Remember that resetting all network settings will delete your wifi passwords as well- so you need to connect again in every place you have joined wifi. Hope this will help many iPhone owners! :)
이 답변이 도움이 되었나요?
Worked for me.. Thank you
Thanks to this advice, I did it! I've rebooted! So grateful.
Oh ok.
Then next to the blue coil there should be white coil
Is that one in its place
Also conect the iphone to itunes that also sometimes gets it back up n runing
Also check the signal antena there little silver pins that go between the loud speaker and the frame if they r broken ur signal is weak
이 답변이 도움이 되었나요?
I had the same problem , I took the Iphone 4 to a recognized technician and he fixed the problem , it was a hardware problem, the part of the Iphone responsable for reception and transmiting I think it is the antenna and the technician replaced it and now the Iphone 4 is working smoothly.
이 답변이 도움이 되었나요?
Had this problem all i did was connect to itunes and boom. signal back on.. worth a shot.
이 답변이 도움이 되었나요?
How To Fix An iPhone That Says Searching:
1. Turn Your iPhone Off And Back On Again
2. Update Your Carrier Settings, If You Can
3. Reset Network Settings
4. Fix Problems With Your SIM Card
5. DFU Restore Your iPhone (But Read The Warning, First)
6. Repair Your iPhone
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 8
지난 30일: 12
전체 시간: 161,496
댓글 14개
My iphone 4 just felt and when i handled it was on "searching".. I though it was some sim card issue, tryed everything and than reseted the phone. Nothing happend..
Now i cant register my phone and its still searching...
any help please?
Mateus 의
did you try the solution written below?
Abdul Galib 의
my iphone also keep on searching signals and at times it indicates that it has no service.. and i will ask also if u can connect to itunes even without signal on ur phone ?? and i had reformat my phone.
Dannah 의
yes u can connect to Itunes without signal even without sim card @dannah
Abdul Galib 의
you can using wifi to connect into iTunes for a while until the prob fix.
felix waukateyau 의
댓글 9개 더보기
