주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1990년부터 1993년형까지 생산된 4세대 Honda Accord로, 쿠페, 세단, 왜건 차체로 출시되었습니다.
How to do valve adjustment
how to do valve adjustment on 1991 accord lx
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
RAJ, here is the way the service manual describes it:"
- Valves should be adjusted cold when the cylinder head temperature is less than 100deg F. Adjustment is the same for intake and exhaust valves.
- If pulley bolt broke loose while turning crank, retorque it to 159 lb-ft
1. Remove Valve cover
이미지
2. Set No. 1 piston at TDC. "UP" mark on the pulley should be at the top., and TDC grooves on the pulley should align with cylinder head surface. The distributor rotor must be pointing toward the No.1 plug wire.
이미지
3. Adjust valves on No.1 cylinder
Intake: 0.010+/-0.01 in.
Exhaust: 0.012+/- 0.01 in.
4. Loosen locknut and turn adjustment screw until feeler gauge slides back and forth with slight amount of drag.
이미지
5. Tighten locknut and check clearance again. Repeat adjustment if necessary.
이미지
6. Rotate crankshaft 180deg. counterclockwise (cam pulley turns 90deg.) The "UP" mark should be at exhaust side. Distributor rotor should point to No.3 plug wire. Adjust valves on No.3 Cylinder
이미지
7. Rotate crankshaft 180deg. counterclockwise to bring No.4 piston to TDC. Both TDC grooves are once again visible and distributor rotor points to No.4 plug wire. Adjust valves on No.4 cylinder.
이미지
8. Rotate crankshaft 180deg. counterclockwise to bring No.2 piston to TDC. The "UP" mark should be at the intake side. Distributor rotor should point to No.2 plug wire. Adjust valves on No.2 cylinder
이미지
Hope this helps, good luck
이 답변이 도움이 되었나요?
점수 5
댓글 7개:
What about the exaust valve's .
Do you do the exaust side at the same time you have The piston at TDC?
Yes, do it at the same time
Hey OldTurkey, Why do you have to rotate the pulley counterclockwise? Can you rotate it clockwise and get to the same place you want to go and not worry about the nut coming loose from the pulley? Just asking, Your the Pro.
Cheers, Alex
Noooo, it always rotates counterclockwise, I would NOT turn it the other direction
댓글 2개 더보기
댓글 달기
all Honda auto have a sticker under the hood that states on the left side to the bottom that states the specks intake /exhaust/ some are in metric intake 26 mm exhaust 30 mm -or intake .010/exhaust .012 I do like to push mine down 1mm to 25/29 since it has a lot of miles on it
Update (08/31/2015)
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
firing order is from the timing belt side drivers side 1/3/4/2 on f22a1 engines an on most Hondas 4 cylenders
always go by your sticker under the hood no matter what anybody says
the best way to ajust valves is to get it ready the day befor an ajust the folling morning when it is as cold as possible for best job
What is the rocker arm assembly torque specs?
댓글 달기
답변을 추가하세요
RAJ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 45
전체 시간: 28,604
