주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Any way to fix charging port short?
Driving down the road, pick up my phone to use it and boom nothing. Won't turn on, won't charge. My battery life has always been awful, so I figure it finally died for good. I take it into the Apple store for a second opinion, Genius points at charging port and shows that covering two of the terminals is evidence of a spark. She said there's no way to fix it. Is the entire logic board shorted out or just the charging port? Could I take it to a shop and have the charger replaced? I've swapped several digitizers and I understand the basics of the phone, but I'm incapable of soldering or anything of that sort.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I guess my real question is, is there any way that when the spark occurred, it completely fried the logic board? If not, I plan on buying this because I think it looks awesome. http://m.ebay.com/itm?itemId=25133207764...
possible, but unlikely. Usually it is the dock connector that fails.
댓글 달기
답변 2개
선택된 답변
Josh, besides not knowing what caused this, I would suggest you start by replacing the dock connector. Here is the guide for it, and the part is available right here as well as many other places. Hope this helps, good luck.
iPhone 4S Dock Connector 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I would start with a toothbrush and rubbing alcohol scrub on the dock connector and a hard reset first...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Josh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 12
전체 시간: 4,261
