주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle 4는 2011년 9월 28일에 출시된 4가지 모델이 있습니다.
Kindle will not switch on
my kindle was fine when I switched it off, but will not turn on again. I have tried this with the mains connection on & off. When pressing the on/off button, the green light comes on, briefly, then --- nothing!
The charging light seems to work, but the kindle will simply not boot! Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 6개
the back won't come off
got the back off wares battery
kindle 4 will not let you take it out what do i do how
the battery is glued down
I fixed it by disconnecting and reconnecting the battery. I followed this tutorial: Kindle 4 스크린 교체 until step 2, then reattached the battery and reassembled the back.
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
I had the same problem as you.All you need to do is hold in the start button for 20 seconds and it will reboot the kindle and it will reload everything.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Worked for me! I think my initial problem was I left the kindle battery to drain for too long. I need to remember to charge it. Thank you!
댓글 달기
i had the same Problem with a kindl. Disconnect the battery from the logic board, wait for about 2 minutes and connect the battery to the logic board. This helped me...
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
After watching fixit so knew how to take back off ,I followed advice about disconnecting battery did this left for few minute.....now have a working kindle again.
can you direct me to get the instructions for removing the back please as i have the same problem.
thank you
댓글 달기
I am having the same issue. How do I open Kindle 4 to do this? Can someone please direct me to a good, reliable set of instructions? Thank you.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
yes i would like the instruction
댓글 달기
답변을 추가하세요
Denis Keenan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 3,241
