주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
혼다의 7세대 소형차 수리 방법입니다.
How replace knock sensor
Where is the knock sensor on the 2005 civic and how do I replace it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 3개
가장 유용한 답변
gary, you'll need to remove the intake manifold to replace the knock sensor. Or you could to reach it from the underside of the engine. Remove the oil filter for more room. The sensor is just slightly above it, and to the left by the coolant tube. The plug is attached to a bracket by the timing cover.
이미지
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Both are very difficult, I managed to get to it from underneath but had to screw and unscrew with two fingers, which was a pain, but would recommend going from under the car
의 공유
How did u manage to break the bolt loose
의 공유
My ratchet wouldn't even fit up there
의 공유
댓글 달기
If you use an offset box end wrench 12mm you can break it free pretty easily then it's on to the two finger twist it will take a while to get it out its kinda a long winded bolt the hard part is getting it bolted back up its a pain in the neck but can be done and going from underneath the car you don't have to worry about intake gasget and all that bs
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Honda Civic 2004 EX where is the knock sensor?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
gary 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 23
지난 30일: 113
전체 시간: 29,165
