주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
16GB, 32GB 또는 64GB 저장 용량으로 제공되는 CDMA 3G 셀룰러 네트워킹(Verizon) 기능의 2세대 Apple iPad에 대한 수리 안내서, 분해 및 문제해결 정보입니다. 듀얼 코어 A5 프로세서가 탑재되어 있습니다. 2011년 3월에 출시되었습니다. 모델 번호 A1397로 식별할 수 있습니다. 수리 시 열을 가하고 조심스럽게 들어내는 작업이 필요합니다.
ipad 2 not activating error
This is sorta a follow up to a previous question I had asked.(Replaced digitizer and antennas, still searching..)
None of the previous problems were fixed btw.
So we were instructed to restore the ipad to factory. Now we are getting the:
"Your iPad could not be activated because the activation server is temporarily unavailable. Try connecting your iPad to iTUnes to activate it, or try again in a couple of minutes.
If this problem persists, contact Apple Support at apple.com/support"
What do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
Mine to just after updating to 9.3 - totally bricked my iPad2
의
댓글 달기
답변 5개
가장 유용한 답변
I would check for damage in the flex between the main board and the cell service board
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hi Jessa,
Vortex's comment below seems to describe the problem I'm having on an iPad 4 which came to me for a battery replacement, it was re-booting every couple minutes.. New battery - No Change, Log files report temperature sensor failure on sensors 0,6 & 1. iPad wont Activate, displays "searching"
Question : if I can find someone that can replace the base band chip, will it function as normal..
Many Thanks
Paul
의
댓글 달기
look into log files..
I think baseband temperature sensor fails working causing the part to shutdown, causing the device to reset, and so on
see also Nathan Rakes post, which ist the effect caused by this
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have seen this error many times on iphones with broken baseband chip after water damage or impact damages.
Itunes trying to read device's baseband chip (IMEI number or something like that) to activate the phone.
I guess same thing happening to your ipad CDMA. Baseband chip looks like not functioning.
Reasons
1- If its water damaged try to clean mainboard shortcuts and resolder corroded components.
2- if it has impact damaged, using hot air on the baseband chip may bring the baseband function back. I dont know What temperature and howmany minutes. But you can google for it.
Good luck ...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi.
How can i check the flex between board and cell service board?
I mean, if i check bouth sides of the flex i have continuty, but how can i check if the pads are soldered well?
Thanks?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
What i want to do with my Ipad 2? Activation server is unavailable?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nathan Rakes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 36
전체 시간: 7,298
