주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년에 HP가 개발한 webOS 플랫폼 기반의 태블릿입니다. 9.7인치 디스플레이를 자랑하며, 16GB 또는 32GB 모델로 출시되었습니다. 수리는 간단한 편이지만, 시간과 끈기가 필요합니다.
bottom of touchscreen not responding to touch
The bottom 1/2" or so is very unresponsive. It takes multiple taps to get a reaction. The rest of the screen appears to operate properly. What's wrong? Is there anything that can be done to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
Traveld, this is usually caused by a defective digitizer or digitizer control board. Of course you always want to try a restore and factory reset first (you may lose all your data) and see if that fixes it. Most likely you will have to replace the control board or digitizer. Start with the cheaper part first:-) Here are all the guides you use for the repair. The parts are readily available. Hope this helps, good luck
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have been trying to doctor, but have run into a road block. I get part way through the process, but it stalls right after the instruction to connect the TP to the computer. Nothing happens after that step so I am unable to complete the doctoring route.
Is it possible to replace defective parts on the TP? What is the source?
Thanks
댓글 달기
Well I myself am 13 but I'm glad to know at least why parts of the screen on my PC doesn't respond even if I can't fix it so thanks anyways. It was $2000 when I got it and it still operates like a PC without a touchscreen should when you first get it only this thing is about 6 - 7 years old.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this problem with an Ipad 2. Replacing the digitizer resolved it. The digitizer connection was not making good contact.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Traveld 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 1,652
