주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 9월 14일에 출시된 Apple의 EarPods 헤드폰은 상징적인 기존 화이트 헤드폰의 새로운 개정판입니다. 모델 번호: MNHF2AM/A.
Right headphone not working
Hi
My right headphone has stopped working. It doesn't play sound but I think it's some kinde of trouble with the cable because when I bend it right over the remote the sound comes back.
Has someone experienced the same problem and have any good advice?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 38
댓글 18개
i have same prob but it still does not show sound when i bend it either in any direction
의 공유
I also have this prblm please help me tell me what I do to repair that please
의 공유
My right headphones had stopped working and it's doesn't play sound
의 공유
My right ear pod stopped working please help me out
의 공유
Mine just stoped working when I bend it I get little sounds of my songs the it goes again if I move it from that spot
의 공유
댓글 13개 더보기
댓글 달기
답변 15개
가장 유용한 답변
Sebastian, those are great headphones, but a bit of a pain to fix. That it works when you bend the cable is indicative of a broken wire/connection. you could try and cut it, remove the insulation and resolder a connector to that end. Check on here for a little more information. Hope this helps, good luck
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
I've got the same problem, but having this problem every year i already know the source. It's the wiring in the jack (for me).
But the EarPod teardown does not include a disassembly of the jack.
의 공유
댓글 달기
Mine breaks constantly and i have no idea why. I always have to get a new pair. The thing is, they always pop open as well, and I don't know how to deal with it.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
the earphones are fake then, they not meant to pop open
의 공유
they are fake
의 공유
For Apple earbuds, just take the cage(griddle looking thing on outside) and remove that with a tiny sowing needle, then pull out a long metal shaped rod from inside, and wash it off with warm or hot water. Make sure you completely dry it then carefully insert it back in its original place. Then pop the griddle cage back on. You just cleaned off any dust, dirt, or wax! Now the connection will work again!
의 공유
댓글 달기
If the earpods working properly on other devices just go to accessibility in general settings and equate the hearing sensitivity of left and right earpods
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
i have tried this and it still doesn't work, my music keeps stopping and starting and skipping without me touching it and the right ear bud doesn't work
의 공유
댓글 달기
My left earbud isn’t working now. The thing is, the wires are not bent, they haven’t been accidentally washed, and they’ve worked perfectly for like 3 months now, and these were given to us free by Apple. And I’ve been using them all day because I have been in the car a lot today. Earlier they were working fine and they were working fine in the store too. But when I get back into the car they aren’t working right anymore? That’s bull and its really starting to make me wonder about Apple.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Take out whatever ear that is not working speaker cushion the little thingy that's on the speaker burn it because your taking the sweat off of the cushion because that is what connects to the speaker to let it stop working but when you take it out with a needle or something burn it when you burn it put it back in that's when it will start working again I DID NOT KNOW THIS WAS GONNA WORK!!!!!!!!!!!!!!!!!!!!!!! TRUEEEEEE THINGGGG
의 공유
댓글 달기
you need to change headphone jack
how to replace headphone jack
it will work on all headphones
이 답변이 도움이 되었나요?
점수 1
댓글 달기
This sometimes might happen if it's unclean. So what you do is take a safety pin and just scrape the dirt out of it. That'll work. If you still don't get the output you want, then I think it's a technical problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I phone 6 earphones right side not working. help me dude
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My rigth side of earphone popped can it be fixed
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My right earphone isnt working too. It gets error i think, because sometimes it works and sometimes it doesnt :( dont know how to fix it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same problem.Try cleaning your earbud with a needle to get rid of all the earwax ,sweat and dirt.I did the same and now the sound is back.Hope this helps :-)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
You do mean, to not directly stick the needle, in the earphones, right? I know that, I'm just making sure you don't mean that.
의 공유
댓글 달기
This isn't necessarily the answer but the problem occurs with the microphone section of the EarPod. It consists of the top of the microphone and the wire connecting the top of the microphone to the RIGHT EarPod. I'll be looking into answers for this. At this point I've diagnosed the issue with the design.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same thing with my headphones; I couldn’t hear out of my right ear when I connected it to my iPad, and it wasn’t broken (or $35 wasted), so I just pushed it a little farther in my device and it worked! These headphones were over ear, they’re a lot better than earbuds.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My left side earpods had stopped working and where can I repair it and if I bend the eaephone jack then it will work and plz answer me where can I repair
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The same thing happened to my headphones, and when I bent the cord, it worked. Instead of having my dad pay $100 to fix it, he simply emailed the manufacturer, who sent me a free new pair within weeks. Try doing that, and you might save money.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sebastian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 240
전체 시간: 151,382
