주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Iconia A110은 Acer에서 2012년 10월에 출시한 Android 태블릿입니다. MicroSD 슬롯, HDMI 포트, 7인치 멀티 터치스크린 디스플레이 및 200만 화소 전면 카메라를 탑재하고 있습니다.
Why is my touchscreen unresponsive?
The problem is my touchscreen will not respond completely. For instance, when I try to click a specific app on the home screen, it opens an entirely different app. On top of this, the screen is starting to turn black on certain parts of the screen. Hopefully I can replace the screen if that is even an option.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
Kyle, either your Acer Iconia A110 is really beat up or you are working on a student project;-) "a specific app on the home screen, it opens an entirely different app." is usually caused by a bad digitizer, and " starting to turn black on certain parts of the screen." is a good indication that your LCD has failed. Anyhow, here is a decent teardown that you can use to replace your display assembly and your digitizer. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
My Acer is not responding. When I went to turn it on it is stuck with the picture of a little robot with his belly open and a red triangle. in the left hand corner it is written Android system recovery <3e> acer Cloud / lost .GIR ... I have tried to put a paper clip in te top but nothing is working . I need help!! Susan
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kyle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 25
전체 시간: 2,091
