주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
Location of Hall Effect [Lid] Sensor
I have a late 2010 MacBook Air that has suddenly started sleeping every few seconds. I suspect a problem with the Hall Effect sensor falsely indicating the lid is closed. I could not find much information on the location. With some experimentation, it appears this is on the left side of the laptop, where the I/O board is located. Is the Hall Effect sensor part of the I/O board? In other words, is replacing the I/O board a likely solution?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Remove the I/O board, you'll see a small sensor on a stack of thickened PCB
이 답변이 도움이 되었나요?
점수 5
댓글 8개:
Thanks. To clarify: The short answer is, "yes." I found the sensor attached to the top-facing side of the I/O board, on a riser as Tom described. I was able to verify that powering-up the laptop with the I/O board removed did eliminate the sleep problem--but, of course, introduced an array of new problems. Unfortunately, cleaning and reattaching everything did not resolve the issue which returned with the I/O board reinstalled, But, I'm anticipating that a replacement will resolve the issue.
My replacement I/O board arrived yesterday, and did indeed resolve this problem. Thanks again.
Hi, i have the same problem with a1502 mac pro. The MacPro went to sleep randomly and waked up soon with open lid. Do you have any part number or picture of the up side of the logic or io board?
Here's the IFIXIT guide to replace the I/O board: MacBook Air 13" Late 2010 I/O Board Replacement. Often I find I need to replace the I/O cable as that sometimes gets damaged. As to a picture of the other side not much to see here: I/O logic bod from Mid 2011 model which is almost identical The Hall sensor is the square block just under the cable harness. I would try using a magnet placing it near the left side Tab key to see if it goes into sleep mode.
Thanks for your quick help. I think i can't solve this an simple part replace.
댓글 3개 더보기
댓글 달기
답변을 추가하세요
Kevin Barr 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 28
전체 시간: 7,740
