주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 Micromax Mobile에서 출시한 스타일러스 펜이 포함된 패블릿 스타일의 스마트폰입니다.
Recover data from A240 internal memory
My phone is not getting switched on. i tried many things
power btton+ low volume key etc.
service centre have said to rplace the motherboard.
i need my data badly from internal memory. service centre is not helping. need some one immediate help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
Data is proprietary (you won't be able to read it). If you can pull the SSD the phone center should be able to mount it in a new phone. If not go up the line until you find someone who can help you.
If this answer is acceptable please remember to return and mark it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
vib, the data is stored on t\some hardwired NAND memory chip. Unless you can build a NAND reader and have the software to access the chip, there is no way you can get to the data. Some data recovery centers do have that equipment, but it is very costly to use their services. Sorry, but a normal DIY'er and normal repair shop will not have access to that method. Hope this helps, good luck
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
vib 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 1,200
