Need wire terminations inside the volume control circuit board
The wire between the volume control circuit board and the xbox got pulled out right at the solder joints inside volume control circuit board. I can easily reattach them but don't know the exact sequence to put them back. Looking at the board I can see the following identifications on the terminals. G, V+,M+,R,L.
Wires I have to terminate are a Common Ground, Red, Blue, Green, Green\white stripe
I can tell from what is loft on the solder joint where the Common ground (G) and Red wire (R) land. Just having problems with the other three wires.
Any help would be appreciated.
좋은 질문입니까?
댓글 1개
I need to see photo of Razer Kraken Pro V2
Volume control circuit board
Same issue wires pulled off - just need to know which wire goes where
If someone can provide photo pls
Colin Ralph 의
