주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Desire는 HTC에서 개발한 Desire 시리즈의 첫 번째 스마트폰입니다.
Why does the network connection break?
After switching on the phone and entering the pin code the home network cannot be found. After some time the network is found but the connection breaks after about 30 seconds. The connection to the network cannot be restored.
The same problem occurs after a reboot. I have tried another sim card of another network provider - same phenomenom.
What do you think?
Maybe it is an antenna problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
- Look at this manual:
http://www.formymobile.co.uk/desiredisas...
The GSM antenna is the small module at the pic 2. Check and clean carefully the contacts (2x).
- Check at the "Settings" - Network connection. If its - manual, change it to automatic.
- Change the network mode to GSM only.
- You can do a factory reset to resolve the problem, if it's software.
If this not help you, ask a specialist for help.
Regards.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jacccooo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 403
