주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mazda Millenia는 일본 자동차 제조사인 Mazda가 1993년부터 2002년까지 생산한 고급 승용차입니다.
fuel pump relay location
I don't know which relay is for the 2002 mazda mellinium fuel pump
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개:
can you tell me where it is
댓글 달기
답변 1개
dale, here is what I found:"Fuel Pump Control System
System inspection
1. turn the ignition switch to START and check operation of fuel pump relay and fuel pump resistor and relay by listening for their operating sound.
2. If no sound was heard, check the fuel pump relay and duel pump resistor and relay (speed0.
3. If the fuel pump relay and fuel pump resistor and relay(speed) are normal, check voltage at following terminals
ECM terminal 1H (Ignition switch start signal)
ECM terminal 1AF(Fuel pump relay)
ECM terminal 1AJ (fuel pump resistor and relay)
Fuel Pump Relay
Inspection
1. Remove the cruise actuator
2. remove the fuel pump relay.
3. Apply battery positive voltage and check continuity between terminal of the relay by using an ohmmeter
4. If not as specified, replace the fuel pump relay.
이미지
Fuel Pump Resistor and relay (Speed)
Inspection
1. Disconnect the fuel pump resistor and relay connector. Measure the resistance between terminals A and B by using an ohmmeter
Specification:0.38-0.42 ohm
2. If not as specified, replace the fuel pump resistor and relay (speed).
이미지
Here is the wiring diagram
이미지
이미지
이미지
Oh yes, the fuel pump relay is located in the fuse box under the hood.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dale 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 3,043
