주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 530 노트북의 모든 모델.
no sing of life
hp dead, water damage, could not turn on,, what should i do, and schematics for it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
waspa, that's a mighty tall order. The very first thing that you should do is to stop trying to use your computer. Remove the battery. Download the service manual from here. remove your motherboard and clean it with 90%+ isopropyl alcohol and a soft brush. While you clean it, check for missing broken or charred looking components. Once it is all cleaned, reassemble your computer and replace the battery, then re-evaluate and see what you get. Any schematic will only help if you know how to read and follow it. You would also need to have the tools and the knowledge to perform board level repairs. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
how to make charger outer for battery for hb 530
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
waspa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 14
전체 시간: 631
