주요 콘텐츠로 건너뛰기
Laptop White Screen Problem (Death of Demons)
SONY VAIO PCG-712211W
when i turn on my laptop white screen nothing else
from bios till window load white screen only..........
i tried on my external monitor works fine no mistake...
i scan my full system no virus at all...........................
i tried disconnecting and reconnecting the display cable of my lcd screen several time but nothing works white screen only............
but one thing i did't get it........................
my lcd back panel circuit board gets overheat when the display cable is connected well i disconnect it heat goes as cool.............................
the problem is in display cable or the lcd display???
i want your opinion
u ans it i FIXIT
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
i had to replace the display with new one because no around our local use to repair display they told to get new one instead of repair so brought from ebay at 52.39 USD
댓글 달기
답변 3개
선택된 해법
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Ajit, the white light is an indication that your backlight gets power. Since it works with an external monitor, and "lcd back panel circuit board gets overheat", is a pretty good indication that your LCD driver board is shorted out. Replacing the LCD panel should fix this problem. Hoe this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Ajit 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 11,460
