주요 콘텐츠로 건너뛰기
Broken Wii U Gamepad ribbon CLIP during screen replacement!
Hello,
I recently broke my Wii U gamepad screen (the digitizer is working just fine)
so I ordered a replacement screen online
the screen have 3 ribbon cables , 2 from the top (screen and digtizer)
and one small ribbon cable on the side , I broke the clip the keeps the ribbon cable in contact with the pins
The game pad is working (I can still play) , but the screen will not power up
is there a way to replace the clip , or any solution to keep the ribbon cable in contact with the pins ?
or do I need to replace the entire gamepad !?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
가장 유용한 답변
OK, this all depends on how skilled you are:
Easy Method:
1. Insert the ribbon back into the slot.
2. Take the broken part of the clip and lay it back down right on top of the pins. If you don't have the black switch then simply use something like a very small flat head screw driver or a needle instead.
3. Put a bit of pressure on the pins then lay a good sized piece of black tape or even glue gun glue on the area.
Skilled Method:
1. Remove any covering on the connector area revealing the bare pins.
2. Either you lay the ribbon on top of the bare pins and glue gun or black tape the ribbon to the pins while asserting pressure, OR use thin wire and soldier the pins to the corresponding contacts on the ribbon, then clean everything up with glue gun or black tape. Make sure the wires don't touch each other.
Either way, the ZIF connector that you broke is the one to the backlight for the LCD of the Gamepad. Basically this component gives the screen light. This repair could be done the same way to any ZIF connector so if you break the digitizer one next, you can fix it the same way.
Take your time next time, your welcome!
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I lost the Riben plastic stuff what to do Thanks D.Rodway Wavey363@gmail.com
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Jesus christ bud,are you really asking this??not a dumb person to ask…but the question is a little dumb since the answer fame up before you ask.
Come on dude
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You will have to buy a new one
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
xojoeox 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 7,030
