주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 2월에 출시된 10.1형 태블릿으로, Android 4.4 KitKat의 커스텀 버전을 탑재하고 있으며 모델 번호 SM-T520NZKAXAR로 식별됩니다.
replace the faulty Charging port?
Does anyone know how to replace Charge Port?
and where to buy parts. find only micro usb ports without cable.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
how do i fix the samung
의
Which samsung? Samsung makes a lot of things, from washing machines to smartphones.
의
댓글 달기
답변 3개
가장 유용한 답변
Try eBay, I got charging port for my galaxy note 8.0...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I've found this (https://www.amazon.com/s/ref=sr_nr_p_72_...) and this (http://www.etradesupply.com/samsung-gala...). I'm still not sure as to how to safely remove the bottom part of the charging cable/port (where the micro usb plugs into the device). It's underneath part of the shell housing that seems particularly tricky to get to. Anyone else have any luck with it?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Have look at this video on youtube https://www.youtube.com/watch?v=9WxerDUD... .
I used it to take apart our non charging SM-T520. It will take some gently prying/lifting of the grey plastic rim to 'free' the mic/charger connector/connector cable. I gently pulled out the connecting part first before working my way to the mic. I am currently waiting for my replacement part (Ebay, ordered complete ribbon cable) so I can NOT confirm that I didn't kill the tablet or not ;) .
의
The replacement mic/charger/connector flat cable arrived today.
I remove the steel cover from the original charge port as it is needed to screw down the new port in the tablet. After reconnecting the previously disconnected bits (not yet seating the cable/mic/etc in the frame of the tablet), I carefully plugged in the charger.
After some 5 seconds the backlight turned on and a brief moment of joy, nothing more than the charger port appeared to be damaged. After removing the charger I reseated the cable properly, fixated the flat cable with the original length of black sticky tape and placed the protective plastic adhesive over the connectors. Again the tablet was hooked up to the charger as to check that all was still in place; OK. The back cover was put in place using mild pressure and the snap retainers to got in their place. Even though the back covers snapped in place there remains a small gap along the edge. I guess the cover got slightly bent during the prying process and is in need of some glue.
의
댓글 달기
You can buy it from here
Galaxy Note 10.1 (2014) and Tab Pro 10.1 (W-Fi) Charging Assembly
Replace the charging port and flex cable assembly for the 2014 model Samsung Galaxy Note 10.1 and the Wi-Fi model Tab Pro 10.1. 이미지
제품
$8.99
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi @nicolasplayz ,
Unfortunately at the moment you can't. It says that it is Out of Stock.
의
댓글 달기
답변을 추가하세요
jonas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 6,400
